Facevarying
Does houdini support the facevarying class specifier? :unsure: If I remember correctly facevarying will allow me to have seperate textures on different primitives (faces) on the same SubD, and they will be interpolated.
For example
Grid- 4x4 polygon
UVProject- planar
Primitive1- Add Texture=grid.tex, Source Group= 1,
Primitive2- Add Texture=flowers.tex, Source Group= 2,
Attribute1- Renderman: texturemap -> texturename, uniform string
Shop1 - basic painted plastic
When i render this as a polygon object it renders as expected, one face has a grid texture, the other face has the flowers texture. But when its rendered as a SubD, it only uses one texture map for the surface. With facevarying things get interpolated on a per face per vertex basis, which will fix this problem...I think. :huh:
Any ideas? :)
Jason C.
  • 6 years later...
So did anyone ever found out if Houdini can export facevarying attributes (st coords, etc)?
The Attribute SOP doesn't have "facevarying" in it's RenderMan mapping.
If it's not supported directly, can anyone please elaborate on how to get that information into Houdini-generated ribs? Thanks.
EDIT:
OdWiki has something on facevarying attributes on RenderMan subdivision surfaces, but it doesn't say how the information is exported to rib.
http://odforce.net/wiki/index.php/SubdivisionSurface
Edited by melazoma
