Automating rops with python
Is it possible to render all existing rops and also rops in obj levels one after the other?
So without manual links?
It is a file with over 100 different rops.
Can i achieve in hscript that a rop in an obj level takes the name of the obj level?
thanks.
Edited by Christoph_H
This page shows the principle:
http://www.tokeru.com/cgwiki/index.php?title=HoudiniPython#press_.27save_to_disk.27_on_a_rop
My problem is that I have no experience with python. I'm just starting to get along with vex.
It would be very nice to give me a hint.
How should the script look like, with which I manage to create my own “mantra rop” with “output path with object names” from the selected objects?
Could I set the scene floor to be added to each one?
thanks.
here is a simple example to render all Mantra ROPs:
#find all nodes of type 'ifd' (Mantra) in the 'driver' context (ROP)
for i in hou.nodeTypeCategories()["Driver"].nodeTypes()["ifd"].instances():
    # display their full path
    print "render: " , i.path()
    # press the 'Render to Disk' Button
    i.parm("execute").pressButton()
render_all_mantra_rop_bunker.hipnc
and this creates a mantra node per selected object and set the image output path based on the node name:
# before running the script, select "a,b,c" nodes
ropnet = hou.node('/obj/ropnet1')
# delete all nodes inside ropnet1
for i in ropnet.children():
    i.destroy()
# create a mantra node for each selected node
for i in hou.selectedNodes():
    n = i.name()
    m = ropnet.createNode("ifd")
    m.setName("mantra_"+n)
    m.parm("vm_picture").set("/tmp/myfilepath/"+n+".$"+"F4.exr")
render_all_mantra_rop_bunker2.hipnc
you can put that script on a shelf button if you prefer, same thing.
if you mean exclude the null from all the selected nodes, you can filter by node types:
# filter out all null nodes
  if i.type().name()!='null':
Edited by bunker
  • 2 weeks later...
