how can I set copy points scale from 0-1
hello guys. I am new Houdini user. I got a question about copy to point. I can't find out a way to get each sphere scale from 0-1 when every time it generated in this case. I need some help to know about the concept to make it happen please. thanks.
here is the file link:
copy to point file
Edited by akaliln
Looking at your file, it looks like you defined pscale not over a 0-1 range. You could use the fit01 function if you want to change your scale. (go into the geometry view for the foreach_end1 node). There are various ways you can define pscale. See attachment for a few examples where pscale was defined by an attribute wrangle.
pscale.hiplc
Edited by Isleofgough
