Waqar Posted May 15, 2018 Share Posted May 15, 2018 Hi, I have created a particle system using popnet.My emitter type is location. There is a sphere in the way of moving particles. I need to add a new velocity from the normals of sphere, to the existing velocity of particles. I tried using attribute transfer. It adds velocity, but only in data, visually particles don't seem to be changing velocity. They just go in a direction, as started from location emitter. Any solution would be helpful. Quote Link to comment Share on other sites More sharing options...
Andrea Posted May 15, 2018 Share Posted May 15, 2018 If you are talking to do it with an attribute transfer I guess you are trying to change the result of the simulation, outside of a dopnet. In this case what you need to change is the position and not the velocity of the particles. Or are you doing it inside of dops? If this video shows something similiar to what you are trying to do, maybe it can be helpful 1 Quote Link to comment Share on other sites More sharing options...
