Getting consistent velocity from alembic animation with changing point count
NNenov
Hello, I have a feeling this is a common issue, but its a bit hard to explain / search for a solution. I've imported an animated alembic file, used unpack to get the points and put it through a trail node to get the point velocities, the problem is that the point count changes as some of the objects "disappear", so you get brief flicks of extreme velocity as the point IDs shuffle, I am curious about the method(s) for dealing with this problem..
Thank you
