jheffel Posted June 8, 2018 Share Posted June 8, 2018 Hi, I've been trying a couple different methods of introducing a start/stop dynamic to a crowd simulation. In the case of a simple walk cycle I want to be able to make the agent come to a full stop (Freezing at its current cycle time), and then after a certain amount of time return to its cycle. I was hoping to avoid using a transition network and zones in favor of a more procedural and random start/stop time by directly controlling the velocity. I'm currently setting my clip to use 'in place' as I believe this gives you more control over the velocity instead of 'locomotive'? I was checking out a couple tutorials that set the velocity to 0 in a popwrangle, but have been running into issues getting it to actually work - it seems like the crowd simulation ignores when I override the velocities to 0? v@v = (0,0,0); Will this method or something similar to it work? Quote Link to comment Share on other sites More sharing options...
Atom Posted June 8, 2018 Share Posted June 8, 2018 (edited) I think you have to turn off Limit Particle Speed to Gait Speed Range as well, if you want to manually manage velocity. That is located on the Crowd State node. Edited June 8, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
jheffel Posted June 12, 2018 Author Share Posted June 12, 2018 Thanks Atom, I ended up messing around with and without that setting seems like if I disable 'Limit Particle Speed to Gait Speed Range' the agents all will start at their initial velocity from the crowd source, and then slowly reduce to zero. Was also finding that if I added in obstacles and wanders that the agents would suddenly go to warp speed because there was nothing constraining their velocity. so for my best results have come from re-enabling the limit particle speed checkbox, and setting the allowed variance on the gait speed to 110%. Then I'm running some really rough vex in a popwrangle to try and freeze/unfreeze over time which is getting some ok results. f@freeze = abs( sin(0.5 * @Frame * rand(@ptnum) ) ); if(@freeze < 0.5){ v@v = v@v * @freeze; i@froze += 1; } Quote Link to comment Share on other sites More sharing options...
