Gamedev Simple Baker
squardis
Hi, I try to bake some heightmap but I get some weird lines. Does anyone knows what this is?
Tried to install different versions of the gamedev tools,
Tried adding my own distance, adding samples, different file formats.. but without any luck.
thnx
2 hours ago, davpe said:
i don't know what that is, but this gameDev baker seems to work rather odd. i prefer the original baketexture ROP which works better for me.
Thnx, I did a search andn that seems to work the sameway as the tool except its in sops, but this gives me just black images for everything now... (using exr / tga for now).
Edited by squardis
yes, those two are the same thing, game dev baker just have reworked interface plus some minor changes. it's supposed to be more intuitive but i don't think so. default baker works just fine, post a hipfile if you care, maybe i can take a look at it.
I noticed it was just linked and not more then just a simple hda /otl. but both doesnt seems to work.. would love if you or any other could figure it out what is wrong. THNX Davpe!
In the file:
In SOP game dev.. I get the lines for displacement. Normal and OA for example are just fine.
in the ROP(texture baker): All is getting black...
simpleRockBakerExample.hip
Edited by squardis
Thnx for your help mate!!!
Now it works. Dont know what the problem was. Maybe the visibility, maybe not... cause I did get the occlusion and normal out of it. maybe it was just the gamedev tool.
Also strange problems with the autoUV tool now. seems like it is still a bit buggy.
hm that sucks... i'm on older 1.8.
but hey, i guess you should be able to install multiple versions and use an asset definition from older release for broken tools (in Operator Type Manager > Switch to definition, in dropdown menu you should see a list of all installed releases). it's a bit hassle but at least you can get it working.
btw. right now I noticed there is already new 1.12 up so maybe they've got it fixed. couldn't find any changelog thou so hard to say
Edited by davpe
