onoise on copied lines
logix1390
Hello,
I have a bunch of lines copied to points.
I make a ramp based on the curveu then apply the onoise function after I copied the lines
It works fine, just that when i increase my noise really high, it seems like the geometry travels in a particular direction and not truly randomized.
I apply this wrangle after i copy the lines
int turb=chi("Turb");
float rough=ch("rough");
float atten= ch("atten");
@P+= onoise(@P,turb,rough,atten)*@Cd.x;
I looked up the onoise function in the help files, and i have followed it directly. Maybe I am missing somthing else?
I will attach my file for anyone that wants to take a look
Thank you
Noise_on_lines.hip
*@Cd.x is the problem, it converts your 3D noise into 1D noise
you can add an explicit vector casting: *vector(@Cd.x)
// I also added some parameters for: frequency/offset/amplitude
@P+= vector(onoise(@P*chf("freq")+chv("offset"),chi("turb"),ch("rough"),ch("atten")))*vector(@Cd.x)*chf("amp");
Edited by bunker
