Dual screen problem (5k screen and normal screen)
Hey, just setting up Houdini on my iMac and I've immediately run into a problem with the dual screen setup…
Firstly, my second screen isn't 5k, and the UI gets scaled really big compared to the main 5k screen. Doesn't this scaling get handled automatically? Is there a fix for this or is it recommended to have two screens running at the same res? This only seems to be happening with Houdini.
Secondly, when I click a menu on the second screen, it opens on the other screen… I imagine this is down to the res issue mentioned above, but I am using a Wacom FWIW…
Thanks!
  • 3 weeks later...
I kinda have the same issue, I gave up looking for a solution a while ago. I just think that's how resolution works. If you have settings set up to "HIGH DPI" under scaling, then surely, the screen with smaller resolution will have a bigger UI and the 5k screen will seem normal.
If anyone finds a way around this, that would be great!
