khasperha Posted April 14, 2006 Share Posted April 14, 2006 hello everybody! well i'm new with houdini, i worked with xsi before my prob is when i'm in pesrp view and vex shading mode i found the view very slow! contrary to xsi (in texture mode). is it normal or is there a configuration to do? thanks ! ps: i found procedural texture amazing! never see that without plugins in other 3d package realy! khasperha Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 14, 2006 Share Posted April 14, 2006 VEX shading mode is evaluting the actually shader code and so is slow, (i guess they may speed it up one day what with some graphics card hardware support), at present it's really only intended for viewing single objects as a quick shader preview. Smooth shading mode supports OpenGl texture maps and is way faster. So if you are just using decal texture maps or something stick with smooth shading mode. You might need to turn on texture display under viewport display options/misc tab. It works in conjunction with the openGl tab of each shader. If you need quick rendered previews of procedural shaders turn on ipr rendering in your mantra output rop. Quote Link to comment Share on other sites More sharing options...
khasperha Posted April 14, 2006 Author Share Posted April 14, 2006 ok thanks you sibarrick for your quick answer! i test that later ,i'll have probably another questions thanks again! Quote Link to comment Share on other sites More sharing options...
