best way to add fields to volume
evanrudefx
Lets say I create a box node than iso offset and set the name to density. I have a volume with density. What if I want to add a temperature field? I know I can duplicate the iso offset, change the name to temperature, then merge the two volumes. Isn't there a better to add other fields? Perhaps using name sop or VDB node?
Thanks
