elenvou Posted June 28, 2018 Share Posted June 28, 2018 Hello there!! I want to select all the primitives that have a specific attribute - @P = 0 - and assign a specific color to them. How can I do this in VEX or with nodes? cheers!! Quote Link to comment Share on other sites More sharing options...
malexander Posted June 28, 2018 Share Posted June 28, 2018 The color SOP with the group set to "@P=0" and class set to Primitive is probably the easiest, though you could use a primitive wrangle if you wanted to get a bit more fancy with the condition. Quote Link to comment Share on other sites More sharing options...
