Ultron Posted June 30, 2018 Share Posted June 30, 2018 (edited) Hi! WHO I AM: I am Tobi from Germany. I work for television and do Animations for kids (2D and 3D). In the Past I worked a lot with Softimage, now I use Cinema. But Cinema isn´t the best tool to do Effects. Thats why I finally downloaded Houdini and try to get into it with tutorials in the moment. I hope I also will have a nice time in your impressive community. MY PROBLEM: I think this isn´t a newbee problem: I have a new test scene and insert: cube, distant light, camera and a mantra node. After that I start MPlay and get this Error Message: Error Command Exit Code: 1 13536: Fatal error: Segmentation fault mantra: Error writing data to image device Sometimes Mpay Starts but after the next start I get this Error Message (with changing Numbers) again. Rendering to Disk and Render View is no problem at all. My System Houdini 16.5.323 Edit: Today I uninstalled this version and tried the 16.5.496. No Changes Intel i5-3570 RAM 8GB Windows 10 64bit Can you help me? Exact Error Message and Crash log is attached. crash.tscho_000_13536_log.txt Edited July 1, 2018 by Ultron Quote Link to comment Share on other sites More sharing options...
Jason Posted July 3, 2018 Share Posted July 3, 2018 Hi, Try a very new build -- there were some updates to Windows which caused some issues with TBB and such. I saw this come and go on the SideFX forum. Try the Daily Build. Quote Link to comment Share on other sites More sharing options...
Ultron Posted July 3, 2018 Author Share Posted July 3, 2018 I did. I uninstalled this version and tried the 16.5.496. No Changes I thought it might be the Firewall but it isn´t either. Quote Link to comment Share on other sites More sharing options...
Ultron Posted July 7, 2018 Author Share Posted July 7, 2018 (edited) At the moment I am on a basic Ocean Tutorial. While Exporting the Displacement maps Idialog crashes as well. CPU and Ram aren´t fully used. Sometimes I can Produce one Picture sometimes not a single one. Any Ideas? Im thinking of reinstalling my Computer... / edit: bought a new Computer - problem solved Edited August 23, 2018 by Ultron Quote Link to comment Share on other sites More sharing options...
