-HEAVY- Posted July 2, 2018 Share Posted July 2, 2018 I found a lot of useful information here to do some basic metal bending with switching the constraint from Hard or Cone to Glue. and i am satisfied with the switch effect - but i have a lot of jiggle at the start, so i think i am on track but not getting it right. when i up the substeps it reduces the bending and jiggle but is this the right way? or do i have to do some more tweaking on the constraint settings? do i miss something? any help would be appreciated, here is the file. thx de Heavy Cone_to_Glue_Jiggle.hipnc Quote Link to comment Share on other sites More sharing options...
ThomasPara Posted July 2, 2018 Share Posted July 2, 2018 The main problem is that your glue constraints arent active from the start. Just merge all your constraints before you put them inside the solver, it will figure it out based on the constraint_names. Cone_to_Glue_Jiggle_fix.hipnc Quote Link to comment Share on other sites More sharing options...
