CinnamonMetal Posted July 4, 2018 Share Posted July 4, 2018 Is there a way rather then cap an end, you close the surface using quads ? The top of a surface, most would automatically use cap sop, if the geometry is of quads; you can cap creating quad geometry ? Quote Link to comment Share on other sites More sharing options...
Axii Posted July 5, 2018 Share Posted July 5, 2018 Hi! Use the polycap SOP with the Fill Mode set to Quadrilateral Grid. It will produce a quad-cap wherever possible, it will fail if there are an odd number of points and provide a yellow warning on the node. Cheers Quote Link to comment Share on other sites More sharing options...
