Fluid solver from scratch
Hey, I took a look at your file and found the problem - on the sopscalarfield node in your DOP network, you had the default operation on "set always". This meant that with every frame, it reset the density field to being equal to the "Source_Density" null in SOPs, hence stopping the solvers from having any effect. If you put it back to "Set Initial" then it will all start working correctly :)
Edited by Stephen Moroz
