ollynash Posted July 10, 2018 Share Posted July 10, 2018 Hi, I'm shattering some geometry in Houdini and applying Rigid Body Dynamics and need to get it back into Maya for rendering. I can successfully create an alembic of the packed geo (there are hundreds of pieces) but it's a large file and renders really slowly in MtoA. I figured exporting an .ass archive from Houdini would be lighter and quicker, but I can't get it to work on this shattered geo....the resulting file size is 300Kb and when loaded into Maya the standin cube remains at globafracturingl zero and doesnt' change size (yes I have switched to Legacy Viewport) I check ON Binary Encoding and Export Shaders in the Arnold Archive option and uncheck everything else. I'm fairly new to houdini so think there must be something else I need to do after DopImport in my rbd sim. Anyone got any tips for success please? Cheers, Olly : ) Quote Link to comment Share on other sites More sharing options...
benne5 Posted July 10, 2018 Share Posted July 10, 2018 If you are using packed primitives. Use the rbd to FBX exporter found in the game tools. Quote Link to comment Share on other sites More sharing options...
ollynash Posted July 10, 2018 Author Share Posted July 10, 2018 I'd rather not use FBX, not very efficient. I have found that checking "expand procedurals" in the Arnold Archive options generates files that are of a reasonable file size (14Mb per frame) and is more what I would expect. The standin changes size in Maya which indicates its reading the geo ok but it still doesn't render, just black frames : ( Quote Link to comment Share on other sites More sharing options...
benne5 Posted July 10, 2018 Share Posted July 10, 2018 The size issue might be a centimeter to inches thing. Try adjusting your scene measurements. Quote Link to comment Share on other sites More sharing options...
