Ignore gravity force for particles when emitter mesh is not moving.
art3mis
Hi
Have a simple DOP network for emitting particles from a mesh source.
Right now when I add a gravity force the particles emit even when the mesh emitter is not moving.
How can I modify this, perhaps with a VEXpression, so that gravity only affects the particles when the emitter is moving?
If you just want to prevent particles from emitting when the source isn't moving, you can create a point attribute on the source mesh in SOPs to use as an "emission attribute" on the POP Source DOP. Try using a Trail SOP to compute the velocity of the mesh, then create an emission attribute based on the magnitude of the velocity vector:
f@emission = length(v@v);
Then use emission as your emission attribute.
