bobbybob Posted July 11, 2018 Share Posted July 11, 2018 I am trying to create a solid object, with hair simulation that can collide with other surfaces. Right now I am using the "Organic mass" shelf tool, to create a solid object of a sphere. I am then applying hair (Add fur) and then adding hair simulation (Also via the shelf tool) I have also added a ground plane. When the solid object collides with the ground plane (And the object begins to deform), the hair simulation explodes. Is there another way to create a solid object with hair simulation, that will work, when colliding with other objects? Quote Link to comment Share on other sites More sharing options...
