Cruzifer Posted July 25, 2018 Share Posted July 25, 2018 Hi Everyone, i am new to houdini and i am looking for a solution in vex for that trivial problem: 1. create a grid 2. store the prims in a wrangle (primid, points assigned to primnum or whatever is needed to restore the topology) 3. use an add sop to delete all prims - keep points 4. restore prims in a wrangle - voila the grid is back i allready had a look at this and tried alot whitout no luck http://www.tokeru.com/cgwiki/index.php?title=Points_and_Verts_and_Prims#Store_point_order_of_prims_via_vex unfortunately, in this example he splits the prims before he stores them - i dont want this - there must be a solution with a loop going through the shared points and generating a new Prim from that. Maybe you can push me in the right direction.. Cheers Cruzifer maybe you can push me in the right direction Quote Link to comment Share on other sites More sharing options...
