Simulation inside a loop
Hi, I have multiple RBD object that are simulated. I would like to cache them separately for the entire timeline since each object doesn't affect the others.
I've been thinking to put everything inside a foreach loop but the issue is where should I put the filecache. If I put it outside the foreach calculates every object frame by frame and not object by object as I would. If I put the filecache inside the loop I don't know how to run it for every iteration.
Any suggestions on how can I do that?
