Curve drawing problem
Clif
In Houdini 16 when you drew a curve, you would get a handy tool that would show a dot on the XZ plane so you could see where on that plain you were placing your CV points and a vertical line from that dot to where you would be placing in the Y direction. This was great for allowing you to get a representation of 3D space on a 2D screen.
As of 16.5 the curve drawing tool doesn't seem to have these visualisations enabled, making curve drawing rather frustrating. Is anyone able to tell me if it is possible to enable this feature, or if it was removed, or if it is just a problem with my setup?
Picture: This is what it used to look like when you drew a curve.
[attach]Screen Shot 2018-08-01 at 11.04.22 am.png[/attach]
Thanks!
