caskal Posted August 10, 2018 Share Posted August 10, 2018 (edited) Hey magicians, Been getting crazy with wire solvers. I think the issue is because I get the points changing over time and the constraints go crazy. I've been reading that I need to create a id attribute with $PT to hold the value, tried that with no luck. Animation works fine until the number changes Any tip will be super helpful, thanks in advance. Edited August 11, 2018 by caskal Quote Link to comment Share on other sites More sharing options...
caskal Posted August 13, 2018 Author Share Posted August 13, 2018 After trying wire solver for around 2 days, I ended up using pop grains, wich works until a new point is spawn and the curve doesnt work because it doesnt has enough samples, there's any way to add something like resample with an expression in sop solver under pops? so it resamples only if there are points needed Thanks Quote Link to comment Share on other sites More sharing options...
ravigr32 Posted November 6, 2018 Share Posted November 6, 2018 i too having same issue .do you find solution? Quote Link to comment Share on other sites More sharing options...
