MoShim0 Posted August 15, 2018 Share Posted August 15, 2018 Hello everybody, I got a problem with default environement variable in Houdini, my home directory path contains special character ("é"). Yeah I know it's bad. This make some errors on startup and some stuff doesnt work. Is there a way to set this prefs directory elsewhere? Thanks in advance ! Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted August 17, 2018 Share Posted August 17, 2018 Hello Tosh, Welcome to the forum. I'm guessing you are in France too. So I would hate to say I would recommend for you to remove the special character from your $HOME variable. Which means that if your user name contains C:\Users\usérnamé (on windows) to change your username to an e without accent. Hopefully you do not take this personal as I'm guessing the variable is your name. I actually converted my french install to windows for some of these reason to work easily with Houdini. You can send in a RFE to SESI to handle letters with accent in them, or to present the user with a warning prior to crash about this. However as most programming does not take into account accents I do not know how they could make enough exceptions to handle it, as it's a more pervasive programming issue. As far as work around. Try setting HOUDINI_USER_PREF_DIR help and link below this will explain it. Plus a post about someone else went through the same issue. Good Luck http://www.sidefx.com/docs/houdini/ref/env.html https://www.sidefx.com/forum/topic/37975/?page=1#post-173517 HOUDINI_USER_PREF_DIR The directory to store user preference files. The value of this variable must include the substring __HVER__, which will be replaced at run time with the current MAJOR.MINOR version string. On Windows and Linux, this defaults to the expanded value of $HOME/houdini__HVER__. On Mac OSX, it will also use this default if the directory exists, else it uses the expanded value of $HOME/Library/Preferences/houdini/__HVER__. Quote Link to comment Share on other sites More sharing options...
