Houdini rendering Geo, renderflag
23 minutes ago, toadstorm said:
your question isn't exactly clear. if you want to render something, put the render flag on it. you can separate it from the display flag if you need to by using ctrl+click on the display flag.
Thnx for the reply.
No it wasnt about rendering, it was about saving geometry with the file node and click render where the render node was not at.
Its seems like I found the whole problem. It is because I had made the project first in H14. wich is based on the old foreach method.
I cant show you the exact way but here I give you the H14 problem If you switch to newer versions.
The older version is a subnet so it can have render flags on different things and will output the renderflags
While the new houdini workflow just export wherever you set the ropfile node
