How to set Tags parameter using python
coresign
  • 9 months later...
i have the same question, i found a way but it still not showing in the tags parameters and exact texture in viewport
here is the screenshot, you can see i checked everything and it works ok, no errors, but still not showing anything
upd: ive been told this is because of parmTemplate i need to setup it and put it back to parameter, somehow, trying to find how
So in this case you actually just want to set the parameter:
hou.parm("/path/to/parm").set({"ogl_text": "1"})
This is because you're just trying to modify an actual parameter, not the definition.
You would use the hou.ParmTemplate.setTags() method if you were trying to set/update the tags of a parameter definition but since the Parameter node isn't an actual parameter you just need to set the values.  Your quick update is correct in that if you were doing it this way, you'd have to take your modified parameter template and assign it back to the definition or node for it to take hold.
  • 2 years later...
