Placing objects on a surface
I’m trying to place instances of an object (copy to points) on a plane with a mountain sop, and have the object’s Y point in the direction of the plane’s normal. Is there an easy way to accomplish this? I’ve spent the last two days sorting through documents on orientation, upvectors, and all that follows, but I can’t find a simple way to accomplish this. Could anyone help me out?
Edited by Paradox^
One other way you can do this is setting normals on the instance points (attribute transfer from the mountain geo). It doesn't give you full control, but your scatter objects Z-direction will always point in the direction of the normal - so you can achieve this by giving your scatter object the right orientation first. To have full control of all three axes you need to combine three vectors into an orient attribute matrix. You can do this with playing around with cross products, but might be overkill for what you're trying to achieve :)
Edited by Tronotrond
