Is there a difference between using geoself() or int 0?
kgoossens
In a typical wrangle in SOPs there's no difference. However in CVEX, there's no real "inputs" that you can count on, so you may have to use geoself() in order to reference the geometry you're working on if it's not directly reading a file on disk.
  • Thanks 1
