kingsoz Posted April 26, 2006 Share Posted April 26, 2006 hey peeps, another quick question!! i've plugged a Turbulent Noise VOP into the nN of the Lighting VOP and it turns the whole thing black?! I know there are millions of VOP's available and i keep getting stuck for example i never know where to connect them!! is there any way of finding out where it should be connected to? like a list of examples? so i don't keep asking about every VOP i need! I know the VOPs i need to use, i lay them out, but there is no clear indication where it should be connected. Quote Link to comment Share on other sites More sharing options...
symek Posted April 26, 2006 Share Posted April 26, 2006 if you will understand what IS the specific VOP you will know in general how to use it and where to plug it. There is no strict purpose of any VOP (except output) since VOPs are the front-end of small programming language called VEX. Would you ask what is division or multiplication in math for? The same here. Try video tutorialas on VOP form Sydney-Labs, 3dbuzz etc and you will find your way to VOP.. and vex in general! see you there, SY Quote Link to comment Share on other sites More sharing options...
altbighead Posted April 26, 2006 Share Posted April 26, 2006 no need to learn anything.. just try matching the same colour and you are good to go .. Im joking. you need displace along normal vop to get the bump . Quote Link to comment Share on other sites More sharing options...
