Centroidal Voronoi Tessellation
RTHMan
I did this before, it's pretty straightforward, but the problem is Voronoi Split SOP that's used by Voronoi Fracture SOP will split up your mesh and disconnect each piece. So you have to use Fuse SOP which creates artifacts as it's not as exact.
I asked SESI to add an option not to disconnect pieces a few years ago.
CVT is also very useful to get a high quality remesh which is why I was looking into it.
Hey @pusat can you show an example where the fuse is creating artifacts?
I would like Fuse to also provide an analytical service beyond the topology operation. And have more ways to control what is fused with what.
Cheers
Edited by probiner
