Why no 'global' 'Enable OpenCL' switch?
Anyone know why there is no 'global' 'Enable OpenCL' toggle on any of the Solver SOPs?
ie I just layed down a popnet, then have to go inside the POP Solver and manually check almost every node for an 'Enable OpenCL' switch (there's about half a dozen or so)
The Flip Solver has many, many more!
Edited by art3mis
Hi Jim, you could unlock the "container" node, whose children you want to enable OpenCL, and then run similar python script as this one:
container = hou.selectedNodes()[0]
nodes = container.allSubChildren()
for node in nodes:
    if not node.isInsideLockedHDA():
        parms = node.parms()
        for parm in parms:
            if parm.name()=='opencl':
                try:
                    parm.set(1)
                except hou.PermissionError:
                    pass
