Node descriptive name shows different than actual value
violalyu
Hi Houdini friends,
I'm not sure if anyone had this before, I'm having this really weird issue where I specify a digital asset to show some info with its "Descriptive Parm" field, and I specified a parameter for it to read, say 'display_parm'.
The result of evalParm('display_parm') shows the correct result, but the actual displayed info is different from this result. In this case it is a string containing 3 parts, the actual displayed part is missing the middle part. It is as if the actual displayed info is using another parm or something. And this is only happening to some of the test cases not all of them.
Has anyone had similar issues before?
Thank you so much!
Best,
Viola Lyu
