Create velocity volume from single volume
bobbybob
How is it possible to convert a single volume, to 3 volumes (velocity)
I have shaped form that I am converting to a volume. I then need to convert that volume to vel.x vel.y and vel.z, to create a velocity field of. it is not optimal to just create a bound and then convert it via a "Volume" node, because I need to keep the original shape.
To explicitly answer your question:
Take your current volume, and place 3 "name" nodes, in each one link it to your current volume and name in the string parm "vel.x", "vel.y", "vel.z" -- place a merge, and combine your original volume, along with the 3 volumes that have been renamed. You'll now have your original volume, and 3 fields for vel.
I think with more context though, there will be a better answer.
Thanks. What I wanted was to create a velocity field only in the object.
I ended up using 3 volumes for the velocity and one more as a density volume that I am using as amplitude for the noise, to keep the noise in the shape itself.
Maybe it would be a bit faster to copy the volume and rename it as you mentioned @TheDude, Thanks for your answar.
Example image:
Edited by bobbybob
