bobbybob Posted September 4, 2018 Share Posted September 4, 2018 How is it possible to convert a single volume, to 3 volumes (velocity) I have shaped form that I am converting to a volume. I then need to convert that volume to vel.x vel.y and vel.z, to create a velocity field of. it is not optimal to just create a bound and then convert it via a "Volume" node, because I need to keep the original shape. Quote Link to comment Share on other sites More sharing options...
TheDude Posted September 4, 2018 Share Posted September 4, 2018 To explicitly answer your question: Take your current volume, and place 3 "name" nodes, in each one link it to your current volume and name in the string parm "vel.x", "vel.y", "vel.z" -- place a merge, and combine your original volume, along with the 3 volumes that have been renamed. You'll now have your original volume, and 3 fields for vel. I think with more context though, there will be a better answer. 1 Quote Link to comment Share on other sites More sharing options...
bobbybob Posted September 4, 2018 Author Share Posted September 4, 2018 (edited) Thanks. What I wanted was to create a velocity field only in the object. I ended up using 3 volumes for the velocity and one more as a density volume that I am using as amplitude for the noise, to keep the noise in the shape itself. Maybe it would be a bit faster to copy the volume and rename it as you mentioned @TheDude, Thanks for your answar. Example image: Edited September 4, 2018 by bobbybob Quote Link to comment Share on other sites More sharing options...
