Disable When / Hide When parameter equal to parameter
probiner
Given two string parameters I tried to check if they are equal to disable another parameter, but doesn't work atm.
{ parma == "" } works
{ parmb == "" } works
{ parma == parmb } doesn't work
Any idea why?
Thanks
Edited by probiner
Here is the documents on this. In short, they can an only look at the resolved values, i.e. a local referenced parameter on the left, and a static value on the right.
http://www.sidefx.com/docs/houdini/ref/windows/optype.html#conditions
So you could do { parma == "" parmb == "" } this would mean they both need to be true in order to work an (and) operation. Or if { parma == "" } { parmb == "" } would be an (or) operation. You can also do ==, !=, <, >, >=, <=, =~ (matches pattern), !~ (doesn’t match pattern) as additional operations. What is a actually quite common is to make a parameter that is invisible (or under a hidewhen under an advanced set of options) that you can use to hide and disable parameter and folder menus.
  • 3 years later...
