Does "primgroup" in class makes sense in findattribval() ?
probiner
http://www.sidefx.com/docs/houdini/vex/functions/findattribval.html
Here's a test with "primgroup"
What doesn't make sense to me is that I thought I had to use the class for "primgroup", and the attribname for groupname, but then there's no input for the actuall attribute name.
Cheers
PRB_findattribval_primgroup.hiplc
it's not a group scope, its literally for treating groups like an attribute
so if you say... "prim", "attribname", value ... it will find @primnum whose attribname value is the same as your value
and ... "primgroup", "groupname", value ... will find @primnum whose grupname membership is the same as your value (0 or 1)
so in your case I'd assume you'd do:
findattribval(0, "primgroup", "prims", 1) ;
however it doesn't seem to do what it says, I'd assume it'll give you 2 as that is the first @primnum with the prims group of value 1, but I was always getting -1, it feels like a bug
you can always use
expandprimgroup(0, "prims")[0];
even though it may be slower
However I assume you were hoping for group scope to limit which prims the findattribval() is searching, so I'm afraid that's not implemented
Edited by anim
