Referencing subnet input
Hey guys! First post here.
Could anybody help me with something hopefully rather simple?
Basically I am making an HDA. My HDA has a switch in the hierarchy which changes if the input 1 in my subnetwork has more or less than 4 points.
The thing is everything worked fine, until I changed to HDA. Before as an input I had a grid, whose string I had referenced in the IF function in the switch.
I am trying to find out what is the string name for a subnet input 1, so I can reference it in my switch, or am I supposed to do this referencing in a different way.
Plz halp, this is the last piece of my puzzle :D
Thank you very much!!!
Hi Ian,
always use relative path in expressions within HDA. As for your case
if(npoints(opinputpath("..", 1)) > 4, 1, 0)
opinputpath pointing to input 1 of parent node relative node where expression is
Edited by vicvvsh
