Noti Posted September 21, 2018 Share Posted September 21, 2018 Hi everyone , I recently encountered a problem : the two pics are rendered with all the same settings but a reverse node act on pink prim , as you see , it is obvious that the effect of displacement is different ( pink part ) . By the way , why the displacement of two prims in the red circle are atypism ? The same P , the same N... with same turbulence , get different results ? Someone help me ? Thanke you . displace_test.hipnc Quote Link to comment Share on other sites More sharing options...
