Add volume field to heightfield
JJ FX
Hi there,
So I want to store my masks in some custom fields. This way once converted to points I can further modify the geo.
Heightfield are just 2 dimentional volumes, so what I need is just add another volume. How can I do sth like @my_new_field = @mask?
to add new or copy existing heightfield volume (layer) you can use HeightField Copy Layer SOP
and then if you need to modify it further in a way you described you can use Heightfield Wrangle or Volume Wrangle
Edited by anim
