Matrix Transformation in VOP
Lately I have been trying to wrap my head around transforming point positions with the use of matrices in VOPs.
To do that, I tried the following:
Lets assume I have 3 points with their position vectors A, B and C which come from an alembic and are constantly changing values.
I use a time shift and set it to $F + 1, and extract the same points position vectors, which are now called D, E, F.
Then I set A,B and C into a 3x3 matrix, transposing it (to get the vectors in columns instead of rows) and do the same with D, E, F.
After all this, I multiplied the inverse of the matrix containing ABC with the one containing DEF (this was not inverted).
The resulting matrix was multiplied with new Position inputs, but the resulting transformations didn't match the original ones...
What am I doing wrong?
Thank you.
I didn´t understand your equation. If you are using positions DEF, you should multiply them by (DEF)-1 * ABC to get positions, A, B and C. If you are using positions A, B and C to go to D, E and F, you math should work, just check if your matrix is correct (use a make xform vop node and compare them).
Thank you for the insight, will do it as soon as I have time!
