art3mis Posted October 4, 2018 Share Posted October 4, 2018 (edited) Hi Trying to get ytini running on Linux(Ubuntu) http://www.ytini.com/getstarted.html I need to convert the following 2 scripts so they work on Linux instead of Mac OS. The first is an addition to .bash_profile alias houdini_setup='dirold=$(pwd); cd /Applications/Houdini/Houdini16.0.557/Frameworks/Houdini.framework/Versions/16.0.557/Resources; source houdini_setup; cd $dirold' The 2nd is an alias to run Houdini from the command line with "houdini_run": alias houdini_run='pathold=$PATH; PATH=/Users/jillnaiman1/yt-conda/bin:/Users/jillnaiman1/yt-conda/sbin:/Applications/Houdini/Houdini16.0.557/Frameworks/Houdini.framework/Versions/16.0.557/Resources/houdini:/Applications/Houdini/Houdini16.0.557/Frameworks/Houdini.framework/Versions/16.0.557/Resources/bin:/usr/bin:/usr/sbin/; /Applications/Houdini/Houdini16.0.557/Houdini\ Apprentice\ 16.0.557.app/Contents/MacOS/happrentice; PATH=$pathold' Can anyone help? I've tried the following Quote alias houdini_run='pathold=$PATH; PATH=/home/jim/ytini/yt-conda/bin:/home/jim/ytini/yt-conda/sbin:/opt/hfs16.5.595/:/opt/hfs16.5.595/bin; /opt/hfs16.5.595/bin/hindie-bin; PATH=$pathold and houdini launches but I get a lot of grep not found errors! Edited October 4, 2018 by art3mis Quote Link to comment Share on other sites More sharing options...
