bennyho Posted October 9, 2018 Share Posted October 9, 2018 Hi Everyone Just short question! What's new node in Houdini 16.5 for VOPSOP and IMPORT ATTRIBUTE in Houdini 13? point vop and import bind? I want to use VOPSOP in microsolvers. Ben Quote Link to comment Share on other sites More sharing options...
acey195 Posted October 9, 2018 Share Posted October 9, 2018 VOPSOPs are kinda dead post H13 They are now "attribute VOPs" in which you can affect all geometry types (point, prim, vtx, detail) by selecting the corresponding node, just like Wrangles. import bind is just "bind" to output, use "export bind" (which is also a normal bind VOP, but with some toggles enabled) Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted October 9, 2018 Share Posted October 9, 2018 5 hours ago, acey195 said: VOPSOPs are kinda dead post H13 They are now "attribute VOPs" in which you can affect all geometry types (point, prim, vtx, detail) by selecting the corresponding node, just like Wrangles. import bind is just "bind" to output, use "export bind" (which is also a normal bind VOP, but with some toggles enabled) you are very wrong, noises are keeping alive vops, a lot of people, including me preffer noises on vops, not to mention that shaders will keep vops on the horizon Quote Link to comment Share on other sites More sharing options...
acey195 Posted October 9, 2018 Share Posted October 9, 2018 I said VOPSOPs specifically are dead, they are no longer supported.. Attrib VOPs are the new thing, which are basically the same, but not completely. Quote Link to comment Share on other sites More sharing options...
