Diffuse color not rendering with custom roughness attribute
Hello!
I can't wrap my head around this one. I applied some random colors on the primitives with the default @Cd attribute & set the roughness to 0.1 on the principled shader. The colors show up and everything seems to work fine.
BUT, just as a test, I tried to bind a custom roughness attribute with the same exact roughness values (0.1 on all primitives, just like it's set on the shader) and when I plug it in, the colors don't come through... I get a black & white render instead.
I am lost as to why the shader/renderer is behaving this way... logically the outcome should be identical & I have no idea why the colors disappear.
custom_shader_attribute.hipnc
