trunksdavid
Hi,
I've been trying to make particles slide down a vertical surface but I want them to stop for a second while in motion, and then continue sliding again. I guess, I badly need help with this. Can anyone help me out ?
I've tried animating the response feature in POP Behavior Detect but didn't work out.
Each particle should have its own movement.
Regards,
David
Hi,
You can either use a POP Wrangle or a POP VOP, and play with the speed directly within your sim (and even group the particles you want to slow and Wrangle only this group), and keyframe a factor you would apply of the speed (or a ramp).
Or you can also tweak your sim afterward, using CHOPS, which also gives you lots of control.
Edited by StepbyStepVFX
