evanrudefx Posted October 17, 2018 Share Posted October 17, 2018 (edited) Hello, I had a question about workflow for a certain problem. In the posted gif, you see how the "shutter" closes on the pocket watch? I only want the individual elements to show inside the pocket watch, not the outside as (as shown in the photo). I have been using booleans to to ensure that the "shutter" only shows on the inside. Is this actually a good idea, though? I eventually will lay out UV's and I am not sure if cutting the geometry with booleans will affect the UV's or something else. Is what I am doing fine or should I just fix it in post by rendering matte layers, etc? Any thoughts would be greatly appreciated. Sigh I meant to post this in general : ( Edited October 17, 2018 by ejr32123 Quote Link to comment Share on other sites More sharing options...
Skybar Posted October 17, 2018 Share Posted October 17, 2018 If it works then its fine. If you do the UVs before the boolean that should work fine too. 1 Quote Link to comment Share on other sites More sharing options...
