crowd dops transition help
logix1390
Hello,
I am trying to get a simple transition to work in dops. I got it working perfectly in sops using the "agentcliptransitiongraph" node and the "test sim_crowdtransition" node.
I remembered to plug the transition graph path into the crowd object in dops... I set up the transition and trigger from one state to another as well. However it still does not work, it only uses one state . I am trying to go from a zombie run to a walk
Any help would be great.
I will attach my scene file for anyone that wants to take a look. Thank you.
transition_help.hipnc
