nMolson Posted June 18, 2012 Share Posted June 18, 2012 I know this is old now but id also like to know how the original crack was created as id like to use a curve that i can control, cant seem to make this work with curves though Quote Link to comment Share on other sites More sharing options...
llldemonlll Posted June 20, 2012 Share Posted June 20, 2012 I know this is old now but id also like to know how the original crack was created as id like to use a curve that i can control, cant seem to make this work with curves though It looks as a simple L-system, maybe from the oridginal presets, you should try it ! Quote Link to comment Share on other sites More sharing options...
nMolson Posted June 20, 2012 Share Posted June 20, 2012 It looks as a simple L-system, maybe from the oridginal presets, you should try it ! I kinda figured but im not comfortable enough with them to art direct the curve easily so id like to make this work with a self made curve, is there a way the L systems are put together that i could match with my own curves? Since the file deletes by Primitive 1, i figured i could draw one curve for the main line and others for the secondaries but it doesn't seem to work for me. any ideas? Quote Link to comment Share on other sites More sharing options...
Ali Haider Posted July 11, 2012 Share Posted July 11, 2012 can anyone advise how to get these cracks by texture map instead of curve over grid? Quote Link to comment Share on other sites More sharing options...
Milan Posted July 12, 2012 Share Posted July 12, 2012 can anyone advise how to get these cracks by texture map instead of curve over grid? Well you could possibly use the trace sop to extract the shapes from an image. I think that with a bit of cleanup it should be able to give you good starting point. Quote Link to comment Share on other sites More sharing options...
