Retime sim
JH12
I've seen a few responses to this question, but still am having no luck, wondering if someone can hold my hand and give me some specific instructions.
I simply want to retime a VDB of smoke to make it slower, interpolating between frames.
I've got a VDB which I've cached out and loaded back in via File SOP.  Now I've added a Time Blend, and then a Time Shift.  In the TimeShift I've changed the Frame expression to $F*0.5 and unchecked Integers.  I'm still not seeing any interpolation between frames.  What settings do I need in my TimeBlend for this to work?
Thanks a lot
Thanks a lot
I think you should use the same expression but for time ($T) instead of frame. I had the same problem I believe and switching to time rather than frames solved it. Switch the method from by frame to by time.
Edited by ejr32123
