CinnamonMetal Posted November 6, 2018 Author Share Posted November 6, 2018 (edited) On 10/30/2018 at 7:25 PM, davpe said: 2 - if you want to specify which pieces go to which tile you just simply build an udim primitive integer attribute with desired udim number and then you can feed it into UVLayout SOP (by which I do not mean UV layout program ) and have your uvs packed into desired uv tiles. Do you mean as such within a primitive wrangler; i@udimValue=1002; Set this attribute as a color visualizer on primitives ? When creating the code from your second post within a wrangler, the UV islands disappear ? Edited November 6, 2018 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
davpe Posted November 6, 2018 Share Posted November 6, 2018 yeah something like that only the udim attribute name is just "udim" i think, to be recognized automatically by uvlayout SOP. not sure at this point exactly. read the docs. my code doesn't give you uv islands. only the udim number. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted November 7, 2018 Author Share Posted November 7, 2018 2 hours ago, davpe said: yeah something like that only the udim attribute name is just "udim" i think, to be recognized automatically by uvlayout SOP. not sure at this point exactly. read the docs. my code doesn't give you uv islands. only the udim number. I want the geo spreadsheet to show me how many udim values dependent on how many uv islands are for each udim value. In other words; if there are three uv islands over three udim values that would be shown, best in detail view at 1001,1002 etc. Creating a point attribute using the attribute udim, then promoting it from points to detail only shows one udim value ? Quote Link to comment Share on other sites More sharing options...
davpe Posted November 7, 2018 Share Posted November 7, 2018 with detail, any attribute can only hold one value per object. so promoting to detail won't work. as for computing number of islands per udim, you can definitely do that with H17 as uvlayout SOP now gives you both island number and udim number. with some vex magic you should be able to get how many unique island numbers are there for each unique udim attribute. but I don't know the solution right now. you will have to start digging on your own or wait for somebody else to give you the answer. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted November 7, 2018 Author Share Posted November 7, 2018 @davpe Hopefully someone can give some feed back on this issue; in the meantime, what should I dig for ? In your second post within this thread, was this solution simply to display the udim value ? Quote Link to comment Share on other sites More sharing options...
