davidyannick Posted October 30, 2018 Share Posted October 30, 2018 Hi, I have to use now Houdini apprentice and Mantra, previously I worked with Arnold, I'd like to know how can I with Mantra create same AOV that I used with Arnold : UV,Wireframe, Ambient Occlusion … These two screenshots is how I did it with Arnold, but I can't find a way to do the same thing in mantra ? Thanks for your help Quote Link to comment Share on other sites More sharing options...
davpe Posted October 30, 2018 Share Posted October 30, 2018 hi, for exporting aovs you want to use bind export VOP. whatever is connected into it will become available as aov. if you want uv, just plug uvcoords VOP into your bind export VOP. for ambient occlusion, plug an occlusion VOP into another bind export VOP, etc. then you have to fill those aov's into Mantra ROP too, but that part is the same with Arnold. not sure about wireframe aov, I don't think we have anything like that in Mantra... i do a separate render if I want a wireframe render 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted November 1, 2018 Author Share Posted November 1, 2018 On 31/10/2018 at 12:37 AM, davpe said: hi, for exporting aovs you want to use bind export VOP. whatever is connected into it will become available as aov. if you want uv, just plug uvcoords VOP into your bind export VOP. for ambient occlusion, plug an occlusion VOP into another bind export VOP, etc. then you have to fill those aov's into Mantra ROP too, but that part is the same with Arnold. not sure about wireframe aov, I don't think we have anything like that in Mantra... i do a separate render if I want a wireframe render Thx for your help Quote Link to comment Share on other sites More sharing options...
